Good day wise forum folk,
One of this springs projects on our 1983 Catalina 30 is to replace the potable water hoses. The current hoses appear to be original and when we replaced the pressure pump last year I discovered all sorts of nasty inside the hoses. Also, it appears one of the hoses in the hot water side of the system is clogged as we have very, very low pressure there.
My question is regarding the replacement hose selection. I've noticed. while window shopping on the internet, a Sea Tech and Whale X color coded water tubing. Are there advantages/disadvantages using this, aside from the obvious color coding for hot and cold, over the old tried and true Trident reinforced PVC tubing?
Thanks!
Thanks!
