Opps- Jim is correct
Jim is correct - I misread the post. I responded as though the problem was about opening ports. Okay! With regard to the "fixed ports" some of the comments will still apply. Huner uses Dow sealant and the jist of a few other items still applyLast summer (the only time one can do sealant work in the Northwest - requires a dry surface, you know!), I removed my skylights (fixed ports) and rebeded them. After LEAKING FOR 10 YEARS (yes, I'm yelling), they have not leaked since, nary a drop!!!!The secret to this success has to do with providing room for the sealant to expand and contract. The 2:1 ratio I mentioned earlier. The factory had some clearances less than 0.003 inches, way too small for 1/2-inch plexiglass. By the formula the clearance should be one inch. I found that even 3/8-inch worked adequately so far.The othe secret is to countersink the screw holes in the gel-coat and on the bottom side of the plexiglass (where the screws go through the plastic. Details of this should be in the archives somewhere as I wrote up a detail on all this last year. Also, a recent issue of Sail magazine (June or July?) had an article that said pretty much the same thing (they must have read my post!). Oh, and don't forget to drill out the screw holes where the screws go through the plexiglass. Same principle applies, give clearance around the screw for the sealant. The factory had the screw holes barely large enough for the screws to fit - way too small.Use bump-ons! Order these from Hunter, cheap- a buck? Keeps the plexiglass off the gel-coat. Used on the newer XX.5 models. Same principle, give clearance for the sealant. Only apply sealant around the primiter of the skylight; don't put any where it rests on the coach roof (except at screw hole locations). Need to allow movement of the plastic and also, if you ever need to remove it you'll still be able to.When removing the skylights be very careful NOT TO APPLY EXCESSIVE FORCE! If it breaks, and it will easily, it cannot be replaced!!!! Take it easy! Don't force it. The plastic can't be glued, either.Although my skylights were originally installed with white sealant, I used black as it is more UV resistant. I masked a standard width (use green or blue tape, not that tan stuff) around the top and it looks good. Keep the lines and sheets out of the sealant for a day or two until it cures.Hope this helps.Like I said, no leaks for a year!!
