Irwin exhaust
Hi Paul, thanks for your response. I fininshed the beast of replacing all hoses. I solved the problem of access by cutting an access panel into the engine compartment wall that is behind the vanity mirror in the aft owners cabin. I used a rotozip set for the exact thickness of the wall. I followed the shape of the cut out in the vanity, it made for perfect access to all hoses in the vent loop area inlcuding both the port and stbd. cockpit drain hoses. I was able to do the job alone because of this access. I also realized that it was easiest to make up the vent loop in advance. I also have a generator and it's vent loop is in the same space. I finished the cut out with a teak frame and notced out the shelf in the vanity to fit around the frame. It looks fine but you don't see it anyway because it is behind the mirror on the vanity. Have a great season, Gary
