Randy
I'm thinking about replacing the cockpit drain hoses in my 84 Catalina 27. Is there anything special I should consider before doing this repair? It seems fairly straight forward--the hoses run from the plastic drain fittings in the cockpit sole to the plastic through-hull fittings in the bottom of the hull, passing through the lazarette floor on their way down. Other than carfully removing the old hoses, and replacing them (and the hose clamps) with new ones, do any of you have any tips for me?Randy
