I've finally decided it's time to replace the 45 year old chainplates on our Morgan 28OI. These are 1/4 x1_1/2" SS Bar stock, externally mounted with 3 1/2" carriage bolts per. No obvious failure but lots of rust running down the hull over the last few years.
Anyway Morgan had welded bushings at the the clevis end. I believe this is to give the clevis pin more bearing area? Our plan is to use 3/8" bar stock to avoid the expense of welding a bushing. Thoughts anyone?
