L
Len
My Hunter 240 has just had its 6th Birthday and I'm planning to replace the centerboard pendant as a preventative maintenance project. The nearest Hunter dealer is 3 hours away so a local boat dealer, very competent with power boats, said he will help by providing a lift, etc. But, I need your help with how to do it so that it doesn't become a really dumb idea. This is what I have so far based on searching the archives: 1. Remove the access cover at base of the compression post in the main cabin. 2. Remove the 3/4 inch bolt on the aft side of the compression post. 3. Raise the boat with a sling lift. questions - how high should the boat be raised when doing this and should the pendant on the cabin should be loose ? ? 4. Replace the pendant with a 7/16 inch low stretch (LS) line 10.5 feet in length. Fasten with a stop knot. 5. Align centerboard bracket and lower boat onto it. question - what are the gotchas with this step, particularly aligning the bracket, any suggestions or tricks of the trade that are helpful ? ? 6. Replace centerboard bracket bolt and the access cover. 7. Celebrate a job well done with a six pack, or so.OK so what have I missed so that we don't get into the six pack early.
