Replacing Bulkhead in S2 9.2A
Jul 6, 2017
3
S2 9.2A Gratitude MD
I'm replacing a bulkhead that supports the starboard masthead shroud chainplate. Water leakage weakened the bulkhead to the point where it would not support the chainplate, When cutting out the bulkhead I found what looks like a 1/4" vacuum hose stapled along the hull facing edge and it was cut up a bit from cutting through the fiberglass tabbing. It runs the length of the bulkhead under the cabin sole and I cannot find where it ends or to what it connects. I do not know if I have to replace.
Anyone know what that tubing/hose is for?
Apr 19, 2010
59
S2 9.2C Lincoln, NE
I have a 1982 S2 9.2 center cockpit boat. When I have had questions about its construction, I've received great service from Scott Bytwerk <SBytwerk@s2yachts.com>. I suggest you email him for information. Great guy.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Probably your head holding tank hose. The tank is against the bulkhead under the settee.
Jul 6, 2017
3
Thanks, I considered it may server as a vent for something, but my holding tank is under the port settee. I'm working on the starboard side that forms the aft side of the cabinet/hanging locker.
BobM
Jun 10, 2004
3,269
Darned if I know that one. Is there a drain in that hanging locker?
