Replacing Bulbs
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
Am replacing the bulbs on my boat with LEDs. Done for Bow and stern. What about the mast light? I assume hunter used the same fixture for many boats for quite a while. Anyone replaced this bulb or know where to find the specs for it?
Jun 3, 2004
71
Hunter 290 Tampa, FL
If you're referring to the steaming light, I'd save the money and not replace it with LED-- Every other light on the boat might get used when disconnected from a charging source, but the only time you'd use the steaming light is when the engine is running (and thus there's a charge coming from the alternator).
Having said that, it depends on what the boat was fitted with, and whether or not a previous owner replaced it. If memory serves, Hunter was using the Perko combination masthead light (link here), which had two 'festoon' bulbs (Link here).
[Note to Admins: No sponsorship intended.]
Dec 2, 1999
15,184
I agree with Jon. The issue is that you do not know if the fixtures have been replaced on a boat that is 25-30 years old. Your best bet is go remove the old blubs and get the proper replacement for your fixture.
Nov 9, 2008
1,338
One problem I've read about with LED steaming lights or all-around white masthead lights is that to a large ship, steaming along, they look like stars, close to the horizon. I can't attest to it personally but another poster mentioned it. Something to think about anyway.
Aug 16, 2009
1,000
My reason for asking was that I don't want to have to go up the stick twice. Since the bulbs can probably be exchanged, I was willing to gamble and at least take something up with me in the probably vain hope of getting it right the first time. I have to visit the masthead anyway to replace the windex, install my gps antenna, reposition my bird spikes, check the tackle and establish my machismo.
