balsa core replacement
I too, had a spongy, leaky cockpit sole in my '77 h30. To make a really long story short, (kind of) I cut away the soft portion with a circular and jig saw all the way through to the engine compartment. That was the whole section forward of the pedestal, leaving about two inches of sole on all sides . I cut some 2X4's and screwed them under the remaining sole, ( the 2 inches ) making a frame. Use long stainless steel deck screws. Next, I cut a piece of 3/4 inch cabinet grade plywood to fit on the frame and encased it in West System epoxy. That was then screwed onto the frame using above mentioned screws. Using West System epoxy and glass matting, I built up the sole and faired it to match the rest of the sole. Read the West System directons booklet, thoroughly. Primed and painted and that was it. Stronger than new and no one has been able to spot the repair. Takes time, patience, and the intial nerve to take a circular saw to your boat. The best part - less than $200.Word of caution - make sure to check for wires, hoses, fuel lines, etc. below the sole before you fire up the saw.For small soft spots, (I had some aft of the pedestal ) drill some 3/4 inch holes through the top skin and force some epoxy in there. Fair and paint. I would try using the 3/4 in. hole and epoxy method on the mast base first before tearing things up. If your shrouds are remaining at a constant tension, I wouldn't worry too much. Check that the I-Beam under the compression post on top of the keel is still in good shape. If that should rust out, you will have problems. Hope this helps.Good Luck,-RolandS/V Fraulein II
