James Simmonds said:
Ok - could they have have made it any more difficult?
I tried to do it myself with no luck. I know have a pro looking at it and he says it could take 3 hours to change. They are proposing installing an inspection hatch in the aft cabin in order to improve the access to the impeller.
Has anyone had any luck with any other approach?
It is a little tough to get at. You have to do it my feel since you can't see from the front. I used my digital camera to take a shot just to have a reference in my mind. I brought a 1/4 drive deep well socket with a little 1/4" breaker bar just to loosen the machine screw. It is a 7 mm hex that is also slotted for a screw driver but forget that! The deep well socket is easy to use with your fingers to fully unscrew or tighten. The little breaker is just to snug up. I like it as it's much smaller then the 1/4 drive rachet.
I also use dental floss as strong thread to lightly tie the new gasket to the cover and then when the screws are in i just cut the floss and pull off. You can also use a little grease to stick it to the cover.
I also use a little dish soap to lube the impellor. I don't worry about the vane direction as it pops to the correct direction upon starting.
The give you extra screws in the box in case you drop one. If been lucky. Caution: do not torque too much. It would sicken me if I stripped or snapped a screw.
Side story: four years ago we bought our beloved 331. Previous owner always had the yard do everything. Everything! Anyway they ask me if I want them to do the spring engine check. $100 to start your engine. I said no i'll do it myself.
Motor sailed to our harbor. All excited with the maiden voyage. Next day with family took a nice sail. Winds died about 5 miles out. Decide to cheat an hoist the iron genny. Ended up overheating and the alarm went off!
Towed back. Had to replace the impellor. Went to remove and the screws were loose! Turns out the yard by practice loosens the screws t drain impellor for winter. Then the snug up in spring. So I made it day one by luck. The suction kept it sealed.
Anyway good luck.....
