Replacing AC breaker panel
obdoor
Jul 13, 2015
39
Pearson 33 NC
I'm looking to replace existing AC breaker panel situated above my chart table on my 1987 Pearson 33 with out replacing or reconfiguring the original face plate. Any suggestions?
May 27, 2004
2,059
You can rewire the panel with new breakers and tinned wire. I assume you have not overloaded the current panel connections with accessories and don't need additional circuits. Uh, isn't the "Face Plate" the basis for the panel itself?
I confess I don't know the Pearson line of boats inside.
obdoor
Jul 13, 2015
39
Pearson 33 NC
You are probably correct. I don't need additional circuits. I'll have to find the appropriate breakers.
Jun 6, 2006
6,990
all the holes and breaker sizes (physical) are standard so you should not have any problem droping in new breakers.
May 27, 2004
2,059
Obdoor, Be careful. All breakers are not standard to your panel set up.
I found that one (brand/year/model) fit and others didn't fit the application, but then my boat was built in 1979.
