Replacing a vinyl name
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Does this eliminate ghosts created by UV discoloration? Is there a recommended pad, RPM and/or cutting compound?
Have a look at our own Main Sail's post here?
Ken
I have a bottle of cutting compound from Collinite. Not sure what the exact product number is. It is okay but not noticeably better than McGuires that you buy at Walmart. Both work just fine. Cutting compound is not the same thing as wax but more like a fine grit polish. If you gelcoat is dull you should first buff it with a cutting compound. That will remove any old oxidized gelcoat. Then wax with a wax containing UV protectors.
Oct 10, 2011
619
Tartan 34C Toms River, New Jersey
I used 3M gel-coat cutting compound about 8 years ago. The hull was a mess, I wet sanded the hull then used the compound and it came out great. Problem is the gel-coat is real thin now the hull is 50 years old, so I don't want to get too aggressive. That is why I'm going with the Woody Wax Compound to clean it up and then apply the 925.
My original plan was to Awl-Grip the hull but I'm from the old school of thought of once you paint it will have to be painted again. Also the cost of the job is high especially for a 50 year old boat.
...Problem is the gel-coat is real thin now.....
Understood.
Well I don't know if the Collinite wax is better than others. My guess would be that the word "boat" on the bottle means you are paying more than you should. Collinite also markets an auto wax. My guess is that it is the exact same stuff but with slightly different coloring agents.
I have had good luck with off-the shelve auto wax products. Two seasons ago, I did an experiment on my H26 hull. I did one side with regular wax and the other with Nu Finish. The wax side looked better so I went back and waxed the Nu Finish side... and WOW! Wax over Nu Finish looked great. It is two years later and my starboard side is still better looking. My guess is the Nu Finish fills in some of the small defects and scratches in the surface and that allows the wax to really gloss up... but it is just a theory. I then went back and tried Nu Finish over the wax on my port side and there was no noticeable improvement so if you try this.... Nu Finish first then wax, not the other way around.
I have a 1995. It was in pretty good shape when I got it. I did use McGuires polish before waxing and that did take of a "film" so I guess I had a little oxidation but all-in-all I started with a solid foundation.
I also have a nice hand-held buffer so I didn't have to work to hard.:thumbup:
May 23, 2016
217
O'Day 1984 23 Island Park, NY
I use to have a really hard time washing cheese out of our pans using really hot water and soap, then I tried filling a pan with icewater. The cheese practically fell off. Comes right out of the dish brush too.
Just a thought. Go with the eraser wheel.
-Will (Dragonfly)
[/QUOTE]
I did something with ice water to get chewing gum streaks of the side of my car once...
73
Beneteau 323 Brookville, IN
Nice responses. I think all of them will work. I couldn't say which was best, but I really like the eraser wheel suggestion. It might be interesting to try a variety for future comparison. Different materials respond differently to temperature, hard glues begin to crack when the two materials they are gluing shrink or expand at different rates with temperature change. Soft glues may get softer under heat and harden right up in the cold. These properties can be interesting to exploit.
-Will (Dragonfly)
The wheel it is!
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
Heat gun on low...... start far away then slowly get closer until you see it releasing. Don't want it to be too close or hot as it could damage the gel coat. Very simple and effective.
Yup. Or hair dryer. Wouldn’t use a razor blade for risk if scratching. Heat it up and it peels right off. Just did it last year.
