my depth meter lcd doesn't work any more. the depth meter stills alarms but i don't know to what depth i'm setting the alarm. i want to replace the depth meter. can i use the same transducer? if not can the thru the hull be replaced without pulling the boat? if yes, how? do i have to be real quick?thought i was describing my problem. went to the boat, pulled the meter. it is a "SR Mariner, DDM-I. i will contact them and proceed from there. thanks to all repliers. i have a long way to go to get everything right on "SHANANAGANS" my 1986 Hunter 34
