I wish to replace my current mast step with a strong and reliable type of bracket and pin mechanism which will enable the mast to raised by one person. The present mast step has a concave cup pointing upwards into which the concave bottom of the mast sits. A photo of the mast step and bottom of the mast is attached. Whilst I do not have construction details for the princess 18 I believe the 4 screws of the mast go through the fiberglass into a pre-stressed beam moulded into the cabin roof. The 4 screws appear to have been smeared with a type of epoxy resin. I believe the only way I am going to carefully remove the screws is by patiently dripping acetone on the screw heads and if that does not work I could try heating the screw heads.
Consequently I would be extremely grateful to hear from anyone who has carried out such a replacement, especially on a Princess 18.
Many thanks
Many thanks
