Replacing a Hunter 25.5 pop top
15
hunter 25.5 West Point Lake
I was thinking of trying to replace my pop top. It has spider cracks and leaks a bit. I would think any company that does molds and create fiberglas castings could do it. Ideas anyone?
Oct 2, 2006
1,517
Jboat J24 commack
DIY fix it as even if somebody made the part the price would most likely shock you
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Seconding what Tom suggests. Even if you have to grind deep into the cracks, and/or add some supports to reduce flexing, and/or repaint the thing, and replace the seal, it will still be alot cheaper than buying a new one.
It's relatively easy to work with fiberglass and gel-coat, and a carefully-repaired pop-top will be every bit as durable as a new one.
Sounds like an ideal winter project ;)
Feb 7, 2010
76
macgregor 25 Beaver lake, Rogers Arkansas
Capt'n Tullys Creeping Crack Cure. West Marine. No plumber jokes pls.....
Jun 9, 2008
1,850
- -- -Bayfield
Fix the pop top
It would be cheaper and easier to fix the pop top. If you don't do fiberglass repair, take it to a fiberglass repair shop. They will strengthen it and make it look like new.
And, since you already have the original pop top, it is not that hard to make a mold of it from it and then make another part. I have done that many times with a lot of success. Of course it is cheaper if you do it yourself rather than paying someone else to do it, but you do have alternatives here.
