Replacing a backstay turnbuckle
Sep 23, 2009
1,477
Yesterday I first noticed a faint crack in the backstay turnbuckle. I would like to replace it today if I can find a replacement.
I am very worried about the keel step mast falling over. Will aft lower stays hold it? Will the main halyard led to the mid boom traveler hold it?
Thanks for sharing your experience.
Aug 2, 2005
1,155
Hello njlarry, We really enjoyed sailing our Oday 34! You have a wonderful boat in my opinion.
Depending on your rigging skill and level of daring this could be a reasonably simple fix or maybe better left to a qualified rigger. The change of the backstay will require work at the top of the mast as well as at the cockpit level. I have been up several masts that have been supported by a variety of temporary lines in addition to the shrouds that remained in place. Most recently we removed a forestay to work on a roller furler that had become troublesome. Before climbing and before removing the lower end of the forestay we pulled the spinnaker halyard forward to a bow cleat and added a lower line on the eye for the spinnaker pole (I can't remember its name.....) to the bow roller. Similar lines taken aft would support your mast while the backstay was removed.
Of course unstepping the mast would allow for a whole lot of projects to be accomplished with the mast on supports in front of you. Cost higher, but risk lower. I think measuring the new backstay correctly would be a challenge. Also, is the backstay split? Depending on what/how much you are changing you could keep some of the rigging of the backstay intact while you work on what is changed.
Anyway, if the mast is kept in place I would suggest using several lines led aft to compensate for the removal of the backstay. You could even add a line at the spreaders as you (or some other lucky person) ascends the mast to do the work at the top.
Best Wishes and Be Careful! Phil
Aug 2, 2005
1,155
OOPS, I just read the title of your post. :redface: If the turnbuckle is all that is being replaced, I would attach a line or two to the backstay and to the aft cleats and remove the turnbuckle with no real fear of the mast coming down.
I agree. With the keel stepped mast it shouldn't be a problem, especially with a halyard tun to an aft clear.
Sep 23, 2009
1,477
Thank you all!
Job is now finished. Rigged the main halyard to the stern cleat and a freind helped with extra hands. The marina store had a new one in box of loose parts that was the exact replacement and now all is right with the world.
Now must run to get a lottery ticket.
Nov 26, 2008
1,970
Endeavour 42 Cruisin
One of the benifits of keel stepped.
I had an insulated backstay installed. Which meant the rigger had to go up to do it.
Ran the topping lift to one aft cleat and a spare halyard to the other stern cleat. No problem at all.
It is nice having several spare halyards to use so I dont have to drop sails just to go up.
Joe
Jun 1, 2004
8,318
You can take tension off the backstay using the mainsheet with topping lift or halyard attached to boom end.
