Replacement water bag forHunter 23.5
Mike B
Can anyone tell me where to get a replacement waterbag for the sink on my Hunter 23.5 ? how many gallons should it hold? Thanks in advance.
C
crazy dave
5 gallon
check at camping stores for this item and you might even try at walmart as I think I saw them there once., crazy dave
Rob McLaughlin
5 gallon bag
I found them at West Marine for about $10, and also in a camping supply store for a bit less. These aren't as thick as the ones from the factory, but you get what you pay for. I have had to replace it about once a year for either a leaky cap or a leak in the bag itself.
Rob Ullinger
Water Tank
I replaced the water bag on our 23.5 with a ridged, roto-molded tank, 5 gal as I recall. I had to enlarge the opening under the sink that is covered with the folding counter, and built a small platform for it under the sink. The filler is in the top of the combing just forward of the combing box for the winch handle, and the vent is a thru hull as high above the water line as I could get. Works great, it can be filled from a hose, or if that's not available, from a 5 gallon jug of bottled water. Rob "Kinship"
