I have a leak in the sprayer hose connected to the sink in the head of my boat. It is made with a corrugated flexible metal housing with a thin walled tube that runs inside (see picture for example). The inner tube, which might be latex, is 5/16" ID x 3/8" OD which means the wall is only about 1/16".
I couldn't find a replacement for the entire metal housing, so I thought I'd replace the tubing instead. Unfortunately, I can't find anywhere that carries that type of thin walled tubing.
Has anyone else needed to replace a similar piece? Where did you get your replacement parts?
Thanks,
Scott
Thanks,
Scott
