Replacement surge coupler
1,306
Catalina Capri 22 Albany, Oregon
I need to replace the attwood drum brake actuator that came on the TrailRite trailer for our Capri 22 as we bent the pawl that secures it to the hitch. I'm thinking about switching to a Titan Model 60 as they seem to be less expensive and I've heard they're better.
So far the best site I've found for the replacement is http://www.trailerandtruckparts.com/TitanDico-Actuators_c_108.html. Has anyone dealt with this company? Are they ok or should I keep looking?
Thanks,
Feb 27, 2005
187
Hunter 33.5 Missouri
Chris,
You can check this company. I purchased a new coupler, lines, wheel cylinders and brakes from them four years ago. http://shop.easternmarine.com/ Good service and very satisfied. Did the work myself. Fairly straight forward installation.
Steve
May 23, 2007
1,306
Steve,
Thanks for the link. Eastern Marine is quite a bit cheaper than the other place.
Chris
