I will mention this once again....
There is;
NO NEED FOR USING A
STARTING BATTERY ON SMALL AUX SAILBOAT DIESELS.
Why?
*These batteries are bottom of the barrel garbage batteries. Cheaply produced with bottom of the barrel components.
*They are 1000%
not necessary for this application
*Because they are starting batteries they do very, very poor service when called upon as a reserve or emergency battery where you
may need to cycle them
Please do not waste your money on a
starting battery or even a
dual purpose battery for a sailboat AUX engine....
Any good quality deep cycle battery will start your small diesel without so much as breathing heavy. It will last longer and can be used as an emergency back up battery without damaging it.
But hey don't take my word for it....
"Trojan Battery:
Can I use my deep-cycle battery as a starting battery?
Deep-cycle batteries can be used for engine starting but starting batteries should not be used for deep-cycle applications. A deep-cycle battery may have less cranking amps per pound than a starting battery, but in most cases a deep-cycle battery is still more than adequate for the purpose of starting an engine."
Why waste your hard earned money on a cheap starting battery when you can get ample
double duty out of a deep cycle product.....
I have deep cycle batteries starting 300HP + engines and they do so with ease. A group 31 deep cycle like the Trojan SCS225 or US Battery DCXC 31 would be a good starting battery for a 76HP Yanmar. Heck I used to start my 6 cylinder Cummins, in February, with a pair of golf cart batteries.
You can always buy a dual purpose or starting battery but you are really buying a fairly low level battery.
