replacement solar panel
2
hunter legend 37.5 dana point ca
does anyone know where to obtain a replacement solar panel for a 1991 hunter legend 37.5.the company that made the original no longer exists and it would be nice to get a replacement that would fit right in the same spot.
Dec 14, 2011
316
Navicula 430 Hunter Toronto
i tried to find one for my 430 and could not............so i took it out and had a piece made out of starboard to fill the space............it worked out very well
Apr 22, 2001
497
Hunter 420 Norfolk, VA
Replacement Solar Panal
I have an '01 H420 w/ a deck mounted solar panel designed to trickle charge the start battery. Like your's, my panel needs to be replaced; and, like you, I have also been looking for a replacement for several years, without success, ... until ...
I located and purchased this panel a few days ago ..
UPG 87501 20-Watt Mono-Crystalline Solar Panel
( you can find it on Amazon.com )
The panel is "hard" (mono-crystalline) instead of flexible, and is mounted in a (removable) aluminum frame, ... but, it measures 16.33" x 19.68", which is a nice match for my (our??) old panel.
I purchased one. It arrived 2 days ago. I removed the panel from the frame it's delivered with and it looks like it will work nicely as a replacement. However, because of the current "interesting" weather here, I have not actually been able to see how it will fit on the boat.
If this is the same size panel as the one on your boat, it may be of interest to you.
Oct 28, 2012
2
what is "starboard"?
Phil P
Jan 6, 2012
61
Hunter Legend 375 Rye, NY
I also have a 91 Legend 375 I purchased a year ago. The starboard frame was cracked and the panel was shot. I purchased a 30 watt "hard" panel from Amazon and made a frame out of teak to fit within the indentation If you are interested in what was a PIA process (it took two weeks of nights and six coats of varnish) but looks really great I will post the details.
Mar 16, 2009
303
Hunter Vision-36 Richmond
If it's floppy, you can get a close replacement size from West Marine. I found one there, but haven't replaced it. It's low on my list.
xcyz
Hunter 376
PowerFilm R7
The original company (Sovonics) did go out of business many years ago. I believe the item (MA-6, MA-12, MA-21 or MA-33) you're referring to is now being made by PowerFilm. http://www.powerfilmsolar.com/products/rollable-portable-remote/r7
The R7 is very close to the same spec's that I received from Hunter for my h376 Sovonics MA-6 panel however, the cost ($18 / watt) of the R7 is many, many times that of a larger, better made ridged panel.
I'll dig up and post the information I received from Hunter on this...
