L
Lou Jacobs
I have a 272LE which I bought last spring, with two minor problems. One is a leaky hatch seal, which, I guess, one of these days I'll have to replace. The other is slop in the pintles and gudgeons that, until I discovered on my first cruise last spring, nearly drove me crazy. At anchor, whenever the boat slightly rolled from another boat's wake, or just a little bit of wind, I'd hear a soft rythmic "bang, bang." I was sure there was a flashlight or comething round (can of peas?) rolling in the bilge or in a cabinet causing this. Finally, at anchor while napping in the cockpit a few days later, I heard it coming from the stern, and realized it was the stern-hung rudder, and caused by wear which had eroded a bit of a slot in the pintles and elongated the holes in the gudgeons. I figured that when I was at anchor, a shock cord around the rudder and fastened hard against one of the pulpit posts would keep the rudder tightly in place and keep the noise from waking me. Now, whenever I leave the boat that is how I leave it, to keep the situation from getting worse. But I am wonderining about a better fix. Has anyone replced the fittings? If so, where did you find them? Cost? What about boring out the gudgeons and inserting some kind of sleeve to make a tighter fit between the parts? Any experience would be appreciated.
