Hi,
I had to replace the fans of the fridge. The fans are mounted around the heat exchanger of the fridge under the seat. I need to confirm the air direction of the fan the is connected to the exit of the compartiment. Do you know if it should blow or suck the air to the fridge?
Thanks
Thanks
