I have an old safgas CNG system that still works well, and I have a source of CNG. However, the primary bolt on my Meco regulator is beyond stripped at this point and I need to replace it, it's fixed to the part so I think the whole assembly needs to be replaced. Essentially, it lightly leaks CNG under pressure when the tank is on, above ~1500 psi, but for obvious reasons I want no leaks.
Does anyone know of a good replacement to the Meco regulator and control valve? Is it possible to change the stripped bolt, or get a better seal so that it doesn't leak when the bolt is fully tight?
