replacement masthead sheaves
Ron
The sheaves at the masthead need replacement. Where can I get replacement sheaves? Are the sheaves for the topping lift and main sail halyard the same? Once I have them what is the best and hopefully easiest way to install them?
bruce cornell
sheaves
there are sheaves in the west catalog, and sailrite, and dr marine, and, and, and. you may have to drill out the old pin and replace with a ss bolt and locking nut. you are going to have to look and see just what is/was there, which means dropping the mast to look/remove/replace. you may have to measure the space, and guess the diameter and match with best fit.
