Replacement Mast 1972 O'Day 23 POP TOP
Aug 1, 2017
1
O day 23 1972 23 poptop Monroe Harbor
Hello I have the opportunity to acquire a 1972 23 Pop Top. Only problem is mast was broken so a new or used one is needed. Does anyone know the size of the mast needed (keel Stepped) and a source? I think it is around 30'. Would prefer a used one but new would be fine.
Other than that the boat is on a good tandem trailer has a new OMC saildrive ready to install a dingy and custom ground tackle. Harken roller furling with a 120 and a dutchman system on main sail. Keel was dropped sandblasted primed and painted re-attached, center board cleaned board has new pin.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
www.drmarine.com sells a mast with hardware less rigging for $2,100.00 It is probably a Dwyer Mast section. D&R Marine also sells standing rigging. Keep in mind that a mast will have to ship common carrier, and shipping gets expensive quickly.
