good luck
I just recently installed an electric head and a custom-made holding tank. First of all, if you do this thing right--especially with no thruhulls--this is a huge project. So don't rush anything, and make sure you think everything through. In terms of thruhulls, most boats generally have two for the head--one to draw water to fill the bowl, and the other to dump when you're over 3 miles out. If you want to try to get away with not pulling the boat out of the water and putting these thruhulls in, I think you might be able to. When I was researching, I did hear about people using fresh water to fill the head--which actually has the bonus of smelling better and being kinder to the bowl in terms of that yellow scum. To do this, you could connect the head to the water tanks--but if you do this, think about the water pressure or a vented loop, and where your attaching to the tank or hoses, etc--there are a bunch of ways to do this wrong. On the other hand, you could look at this as a waste of fresh-water. If you don't care about that, it could save you having to put in a thruhull. Also, you could get away with having no dumping thruhull as well, if you plan to always pumpout at a dock--I would do this only if you don't plan to go offshore with the boat. The way pumpouts work is that you put a fitting on the deck, connect a hose to it that goes to the tank. This entails drilling two holes in the deck--which you are going to have to do no matter how you cut it. The first hole is what they hook their suction hose to, and the second is an air-vent, which you connect a hose to, and attach it to the tank. The air-vent keeps the tank from imploding when you're sucking. Like I said, you lose some fresh water, and dumping capabilities, but I guarantee you that you would save serious money. You could also think about a Lectra-San that Peggy could tell you about.
