Seacocks vs Ball Valves
Since you are on an inland lake I doubt that you've experienced any substantial corrosion of a bronze thru-hull,but check it out for any signs of electrolysis before deciding to replace it. If it's solid and the bronze shows no pitting or a teltale pink color you might just keep it in place and using a penetrating oil/ solvent like PB Blaster or WD40, spray the gate valve / thru-hull threads.I would use only bronze ball valve with stainless ball (not Marlon). I believe the manufacturer was Apollo and I have read West MArine's disclaimer. I had no problem threading a 1-1/4" NPT valve sufficiently onto a straight thru-hull, and the sink and head discharge installations are now over 10 years old.Assuming you're out of the water you won't need to worry about incomming water. If not you could use a wood plug in from the outside of the thru-hull, or heel the boat at the dock untill the opening is out of the water using a halyard brideled to a midpoint of the mast and fastened to a piling further away.While holding the thru-hull's collar nut with a large pipe wrench or aircraft pliers, back off the gate valve. Clean the threads test fit the Ball valve. You will typically have straight thread on the thru-hull, however the ball valve should thread at least 3/4" onto it. Then apply a small bead of non-hardening sealant to the threads and hand tighten down the ball valve , making sure the thru hull isn't rotating. Continue to tighten the ball valve onto the thru-hull threads untill well seated and tight. Don't go so far as to bind up the ball itself, which can happen with marlon fittings.If you elect to install a bronze seacock it will be more labor intensive. You will have to do it with the boat out of the water and with the thru hull backed out. Again you would need to insure that the thread types are compatible and possibly get a new thru-hull with shorter threads. You also need a special internal wrench to tighten the thru hull into the seacock after applying appropriate thread sealant and bedding sealant. 1-1/4" thru-hulls and 1-1/4" ball valves should last forever in a fresh water sink drain application.
