Replacement Faucet Handles?
44
Hunter 336 Patchogue, NY
My galley and head sink faucet knobs on a 2003 H326 are all stripped - using vice grips to turn on water.....I can not locate a web site to buy replacement knobs....if you have replaced can you point me in right direction?
Thanks
Dennis
Jul 29, 2004
413
Hunter 340 Lake Lanier, GA
Dennis, I replaced ours (1999 H340). While I don't know your boat, it's worth a trip to your local Home Depot or equivalent after taking off one of your faucet handles, and look at the universal replacements. Also consider removing the entire valve stem and replacing the washer and O-ring.
If you can do this job at home, you can do it on the boat.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Yes, go to your local Home Depot and pick a replacement for the fixture and replace.
Dec 2, 1999
15,184
Dennis:
Do yourself a favor. Go to your FAVORITE home improvement center for a replacements. There is no difference other than the quality and you can get parts for them too. Something like a Moen or Delta.
Oct 14, 2005
2,191
I replaced...
the valve stems on both my galley and head sink by taking one of the valve stems from the existing fixture to one of my local home improvement centers and matching it to one of the many choices available. Note that there are right hand and left hand versions of the same valve for hot and cold side. Total cost was around $25. Replacement knobs that will fit the stems are also available.
