Replacement Diesel for H27
Jun 26, 2016
21
Hunter 1979 Hunter 27 Cherubini Roswell
The diesel for the h27 I bought is in pie especially, and the seller presumed it had had a blown head gasket.
Attempt to repair? Or replace? If replace what make and model would be best?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
see if that is all that is wrong with it and if that is the case fix it
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
do you have mechanical skills if so get the manual and give it a go or find someone that can give you a hand and try to fix it
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
Repair is drastically easier and cheaper. Head gasket not that big a deal if you're handy.
If replace, Beta 16 has good power and torque, fuel sipping, small, smooth running, easy maint. Perfect motor for your boat size.
Mar 15, 2013
197
Islander 32 mkll Comox Hrb.
I second Skippers recommendation for a Beta, good suport, good engine! But if the hours on the original engine aren't to high it will be much more cost effective if you do a minor rebuild. what make and model is the original engine?
Hunter 30_74-83 Rochester, New York (Lake Ontario)
Dana,
I replaced the original Yanmar YSM12 on my 1979 Hunter 30 this year. The Yanmar ran fine but I was looking for easier maintenance, more power and smoother running. I chose a Nanni 3.21 which is based on a Kubota diesel as are many of the Beta's and Universals. I found the price to be significantly less and Nanni has an been excellent to deal with. It may be worth checking out Nanni if your decision comes to replacing.
Cheers,
Bob
Jun 26, 2016
21
Dana,
Cheers,
Bob
Wow. That's a nice looking motor. But it looks quite a bit bigger than the Yanmar in the H27, although I could be mistaken. Is this the right motor shown in this video?
Dana,
The motor in the video is the one I put in my 1979 H30 and suits it very well. It is worth noting that Nanni makes comparable sizes to the Beta's and Universals using the same Kubota engines they do. I also agree a 16 hp twin cylinder sounds like a good motor to consider for your application.
I have dealt with Hugo Stamp (The authorized Nanni dealer in Florida) and have nothing but praise for them. Price and service has been outstanding.
Regards,
Bob
braol
Apr 16, 2014
348
Hunter 27 Rebel 16 Great Lakes Naval Base, IL
Or pull the diesel out and go 4-stroke outboard power. Think of all the room for beer and ice!
