Replacement compass
Oct 13, 2017
22
Hunter 240 Great Salt Lake Marina
The bulkhead mounted compass on my Hunter 260 is not working and the clear cover is scratched. I need to replace it. I purchased a Ritchie SR-2 Venture but it would not fit in the cutout or in the bulkhead. The cut out appears to be about 4 inches and the space in the bulkhead looks to be 5 1/2 inches. Any recommendations for a compass that will fit? I was looking online as a Platimo Mini-Contest bulkhead mount but I'm not sure it will fit.
-na -NA Anywhere USA
I cannot recall but only two worked to replace with on the port side of the companionway. SBO store will know what to recommend as they have the specs and build list on your boat.
Oct 13, 2017
22
The Plastio Mini-Contest is a good replacement. Installation only required cutting a small notch at the bottom of the existing hole to fit the Mini-Contest. They provide a stick on template that makes it easy to cut the notch and to drill the new screw holes. When installed, it did not cover the old screw holes, so thoese were filled with silicon.
Oct 13, 2017
22
Ok. Should have checked spelling. The company is Plastimo. You can download a printable template to use to check before you order.
