Replacement Cabin Lights for Hunter 336
Jul 6, 2013
51
Hunter 336 Société Nautique de Genève
I need to replace a brass 12V cabin light on a 1995 Hunter 336. Does anybody know where to source these lights? I tried to link a photo (1st time... hope it worked).
Jan 4, 2006
7,600
From the look of the mount to the ceiling, and knowing Hunter, I'm going to say that's a PO installation. Hunter always uses a raised mounting base on any of their light installations which gives them a more professional look.
I don't see anything on the SBO chandelry, so you may want to look at other marine suppliers on the web.
Jul 6, 2013
51
Thank you all for your suggestions. The first one on Dave's list matches from a size and shape perspective, but it only comes in white. West Marine has a similar one in brass, but it seems a little smaller (WM #12668299).
Far from being an interior decorator, I'm thinking that matching the color with a slightly smaller size would look better than matching the size in a different color.
Thanks again!
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Hey those lights look like the ones I replaced on our boat. I didn't worry about matching them. In our case, the old ones had halogen bulbs that melted into the sockets so they couldn't be replaced. I see a bulb melted into a fixture as a safety hazard so they all went out with the trash. I got a good deal on some LED replacements that don't look the same, but work fine. No reason to have them match if I'm changing them all. I'm not sure where I got them, but it was online.
Here are several that would work fine:
http://shop.sailboatowners.com/search.php?brand=sailboat&kw=reading+light
Ken
Jul 6, 2013
51
Ken, Thanks for your suggestions. Had the same issue with the bulb fusing to the socket so I will change them all at some point like you did. Dan
