Replacement bimini top for a Hunter H33 (2011)
Feb 12, 2026
1
Hunter H33 Havre de Grace
I am looking to replace my older 'blue' bimini top with a'red' bimini top fpor my (2011) Hunter H33. I am having a hard time searching on where I can find a new bimini top. Does anyone know of a good source?
Jan 4, 2006
7,671
Best advice is custom job
The only advice is a new bimini cover as no two boats will be exactly the same. You may or may not be able to adapt your older "blue bimini top" to your newer 2011 H-33. The SS frame will not likely fit. If you can, keeping the frame will save you a fortune in a new bimini.
Time to get out in the cold and see what you're dealing with.
IF the frame fits the cost of new panels is way less than a new bimini. I'm not clear on if you are trying to fit an existing Bimini to a new boat or simply trying to change the color of the existing Bimini on the same boat.
Jun 17, 2022
539
Hunter 380 Comox BC
I'll echo the comments above. The bimini top is the easiest / cheapest piece to make. Even if yours was provided as a factory option, the best choice is to use the one you have as a template to get it remade. Just a couple hours of work.
Jun 9, 2008
1,850
- -- -Bayfield
There must be some canvas shops around that make up boat covers, etc. that can make you a new bimini. If your old one hasn't shrunk badly, it might even be useful for a pattern.
