Ron
My Hood SeaFurl 705 LD roller furling lost half of the upper bearing on the top most extrusion. The bearing comes in two halves that surround the forestay and align/center the extrusion to the cable. The furling is on my Hunter 28.Has anymore replace this bearing? I'm in the yard and would prefer to change it out by removing the furling on deck from the forestay and lowering the estrustion in order to replace the bearing. The other (less preferred) way is to go aloft and wrestle with it up there.How difficult is it to remove the Hood furling from the forestay and lower the extrusions. Any tech procedures out there?This appears to be a simple remove and replace job - but then again...
