A
Andre K. 1991 Hunter 30
Does any one have a practical and mess - less way of replacing the colant in the engine/heat exchanger/hot water tank? if you just open the valve at the side of the engine, it will not drain all of the colant. I am also affraid to create and trap an air bubble in the water heater, which will make the heater ineffective or will compromise the cooling of the engine.Any ideas will be appreciatedThanks
