Replace rubber rail on stern sugar scoop
1
Beneteau Oceanis 370 Emeryville, CA
I have a new to me Beneteau Oceanis 370 (1991). I would like to replace the rubber rail on the stern sugar scoop. Has anyone done this and is there a source for the rubber rail?
Thanks,
Mark
mtm124
Sep 20, 2010
3
Beneteau 461 Corpus Christi, TX
Would be interested to know as well. We have a '99 461 and the rubber trim no longer meets the teak toe rail. 1.5" gap. Was pulling up so we had a local do some repair to anchor it down and seal it but i would be interested to know if they can be purchased (probably from beneteauusa) and what is involved in replacing.
Beneteau 323 Annapolis MD
I'm very sure this has been covered before, but I don't know what words you'd use to do a forum seach. I wich I'd kept track of it, as I'm sure my 323 will need it sometime.
AndyR
Oct 13, 2007
26
Beneteau 393 Blairgowrie Vic Australia
Hi, We replaced the buffer strip on our B393 a couple of years ago after some idiot had put a soft rubber moulding on there which just fell off first time in a seaway!!! The hard PVC? moulding is available from Beneteau.
The secret is to heat the moulding before you try to apply it, we tried a heat gun without success in the end we put it in a big drum of water with a gas heater underneath and brought it close to boiling, applied lots of white sileastic adhesive/sealant to the transom join and just fed the moulding friom one end. Worked fine but we did put a couple of 6mm SS bolts at the top ends and 2 around near the bottom just to secure it, but i am not sure these were necessary.
best of luck
Andy and Barb on 'AMALIE'
Blairgowrie Yacht Squadron Melbourne Australia
Sep 24, 2006
236
Sabre 36 Express Chattanooga, TN
I did it today!
Great timing for your post. I just put a new vinyl trim on the stern of my 2002 B361 today. I ordered the vinyl from Beneteau (about $90). As others have said, it is a bitch to get it on. It was 85 degrees here in Chattanooga today so I went for it. In preparation, a couple of seeks ago I had "mounted" the vinyl on two 8-foot 1 x 4s to try to straighten it out. It helped some. I also used a hair dryer/heat gun. The thing that seemed to help the most was soap and a small crowbar. At any rate, I got it done, but will probably be sore for a week. :dance:
Also, after I finished, there were lots of black marks from shipping and from the rubber mallet I used, so I wiped the vinyl with MEK (very lightly)! It looks fabulous. The boat looks brand new, since I had the hull buffed last month.
Go for it, and you will save a month's membership at the gym. :snooty:
Agaliha
