More thoughts (a bit long)
Since I'm in the process myself, here goes...The factory mount is fixed, so the new bracket has to be mounted higher up on the transom so the motor mount will be at the same height as the factory mount when it is down. Measure from the top of the mount to the bottom of the skeg, then raise the mount and measure from its top to the waterline to see if the skeg will clear the water. I suspect it won't with the 10-inch mount, but then you can always tilt the motor like you did with the factory mount to get everything out of the water.The only difference between all the mounts I looked at was the retractor spring. The mounts that were rated for bigger motors (more $$$) had stronger springs...that was it. The frames were identical. Look carefully at all the available mounts before you buy, The least expensive one was fine for my 8hp Nissan.Since the new bracket will be mounted higher on the transom, you'll probably need a new backing plate. Ply or Starboard should be OK. If you use ply, paint it with epoxy (West System or Epiglass) before you install it to keep the water out and prevent rot,Do the same when you drill the new mounting holes through the transom and backing plate. What I did was overdrill the holes and fill them with epoxy. I taped over each hole on the inside, made a cup with tape around each one on the outside and poured epoxy in. I had to repeat the process several times, as dry wood absorbs epoxy like you won't believe.Eventually the wood around the holes will become saturated with epoxy, at which point the holes will stay full as the epoxy cures. Give it about 24 hours then redrill the mounting bolt holes to the right size. It takes some time but water will NEVER get into the transom core or the backing plate (if you're using play).While you're at it, use the same technique to fill the holes left by the original mount. You may have to leave the holes open for a few days when you first remove the factory mount so that any water in the wood core of the transom can dry out. Pouring acetone or denatured alcohol into the holes will speed the process. So will a blow dryer...just don't do both at the same time.If you dry out the existing holes before you drill the new holes, you will have eight holes to work on using each batch of epoxy. That's efficient yet comfotable, as you should have about 20 minutes of working time before each batch of epoxy starts to set. Uncured epoxy also cleans up easily with denatured alcohol.Moving the swim ladder, battery and stern light to the other side is a personal choice. I've seen it done both ways. Personally I don't think it's worth the hassle. I just got rid of the water tank.PeterH23 "Raven"
