Replace or reseal the pointed salon windows
G
Greg W
I believe I may have a leak in one of the pointed salon windows in my H31. Has anyone replaced or resealed those windows. There are two aft (one on each side). Does anyone make a replacement or are they fairly easy to take apart and reseal. Instructions would be welcome! Thanks, Greg W.
Nov 26, 2006
381
Hunter 31 1987 Fly Creek Marina Fairhope,AL.
replacement ports
Greg, Ssome where on the trim ring inside the port, ou should see the name of manufacturer. On my hunter 30 , it was gray marine. I found exact replacements for them here in the chandlery. http://shop.hunterowners.com/detail.htm?fno=0&group=645
Dec 2, 1999
15,184
Replacements at Mark Plastics in CA.
Greg: If you pull off the trim around the port you can just use some caulking to try to reseal the ports. If you decide to replace them, you can purchase them from Mark Plastics in Corona Ca.
