I have a 78 Hunter 28.5. It's about a 40' mast, plus the mast step in the cabin.
1. I found that the antenna match from my radio to my Marine antenna wasn't as good as it used to be (SWR was 1.2:1, recently over 4:1). I ran a "TDR" (Time Domain Reflectometer) and found that it was failing at about 26 feet up the coax). (So, I'm a ham radio geek, I know this kind of stuff...)
We went up the mast, changed the antenna (no problem) but the coax wouldn't move inside the mast. From the bottom of the mast the coax wouldn't move. From the top, we could pull out about 4' of excess coax out of the mast, through the hole. After that it's stuck! I'm guessing that it's stuck where the coax failure is (pinched line?)
OK, so we have to replace the coax. Not sure if I could run an electrician's fishing tape up (or down) the mast. Going up, how do I get it through the small hole at the top of the mast? I'd rather run it so I could pull the coax DOWN the mast, so I can have the coax connector already mounted on the coax (as opposed to trying to put the connector on up at the top of the mast!).
Does anyone have any experience with what's inside the mast? Should I be able to fish a line up or down the mast?
2. Also, I wanted to change the light bulb at the top of the mast. I had some regular 'festoon' bulbs (Pointed on the end), but this bulb has a dip on both ends for the two connections to press in. Reference the attached picture. I've tried to read the numbers on the bulb, but as close as I can make out, it's "A8CS25" or just "CS25". Of course I'd like to replace it with an LED bulb, if I could find one.
A. Any idea what the bulb may be and where I can find it? It's 1.75" long. 12V, 10W
B. Would I be better off replacing the whole mount?
3. The Anchor light (half way up the mast) is burned out and I guess I've just resigned myself to replacing the whole unit (3 3/4" between the mounting holes).
Sir Michael
Sir Michael
