Replace head faucet on 1995 Hunter 336
Aug 22, 2022
11
Hunter 336 New London
I’m trying to replace the faucet in sink in the head of my 1995 Hunter 336. I took off the two nuts under the counter but the old faucet won’t come loose - even though the two water lines going into it are completely disconnected. It seems as if the faucet is glued to the counter. Should I just try to pry it off, or am I still missing some other nut to unscrew? It is difficult to see under the sink and the replacement faucet only has the two nuts to hold it down. Any advice?
here is another view
View from under the sink before removing the plastic nuts
Catalina 320 Dana Point
It is typical practice to bed a faucet with something, usually plumbers putty that seals without a lot of adhesive strength. Someone might have used an adhesive sealant instead.
Just to be clear, you have removed the large WHITE retaining nuts under the sink?
Mar 6, 2008
1,532
Try hammering from the bottom gently on each valve. Then insert a large screwdriver in each valve from bottom and rock fore and aft. It will let loose eventually.
Aug 22, 2022
11
Right…. Even after removing those it won’t come off. I’ll try JoeWhite’s suggestion over the weekend and report back. Thanks!
Mar 8, 2019
111
ODay 322 Bodkin Creek, Chesapeake Bay
Looks like black sealer around the base on top that you need to break free.
Debond and other solvents can remove the shine of the fiberglass sink if you leave it on long enough to do any good.
I'd try using a good old straight razor blade and once started some dental floss or safety wire. If you twist the floss it can act like a fine hack saw.
Aug 22, 2022
11
Happy to report that the hammering worked. It broke it loose then it was just a mater of prying it off. It had a rubbery gunk all over but it eventually came off after using a scraper and a little goo-be-gone. Thanks for the advice. Below are a few more pictures.
