Not at boat for a few weeks. Does anyone know if there is a 12v LED solution for the H23.5 cabin lights? Thanks.
You might want to go to the Marinebeam site and watch the video about "Constant Current". After seeing and learning about that, I won't use the cheap LED's. Could be a fire hazard.for cabin lights, I get cheap ones from a local auto parts store.
You're probably right. But my boat does have shore power, with battery charger and a solar charge controller. True the lights are only on at night, so that eliminates the solar charge controller. But sometimes I have a shore power connection while in a marina, that activates the battery charger, which goes through three phases, bulk, absorption and float, where the voltage levels change, and go to 14.4v. I'd rather pay a little more and buy bulbs that control the current delivered to the bulbs.That is an interesting article from Marine Beam. I suspect it is more of an issue/risk on larger boats that have alternators, shore power to charge batteries, etc. For the smaller boats that have basically a single battery, perhaps an outboard with an alternator, perhaps solar panels with a charge controller, etc. I suspect it is less of a risk, particularly when used for cabin lights that would normally not be on when any kind of charging is active. I'd probably pay some extra for the few lights that are hard to access, on the mast, just for the extra likelihood of it not failing mid-season. Now, I might not buy Chinese made bulbs from say eBay, but maybe from a reputable auto chain store.
Ha! I had no idea I was about to burn down. Thanks to all who responded. Doubt my battery would ever see a 15v charging source, but I might do something stupid, like, "yeah, let's hook up the drill battery..."I upgraded all my lights to LED. Check out Marine Beam. They have some informative information on their web site explaining "Constant Current" technology and why it's important.
http://store.marinebeam.com/constant-current-1/
