Replace Fuel Lift Pump on 3GM30F
Jul 6, 2013
51
Hunter 336 Société Nautique de Genève
I plan to replace the fuel lift pump on a Yanmar 3GM30F powering a 1995 Hunter 336.
I wondered if this job is within reach an engine maintenance novice.
Any particular tips or watch-outs?
Thanks!
Dan
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
When mine went out on my 2gm the mechanic replaced it with an electric fuel pump he located close to the fuel tank and wired to the ignition switch. When you turn the switch the pump starts. Makes priming really easy. The electric pump just pushes fuel past the diaphragm in the pump. Some people buy a cheap $20.00 pump from napa but my mechanic insisted on a more expensive and dependable pump. Was about $200.00.
Jan 30, 2012
1,154
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
Two bolts hold the pump to the motor. A gasket seals the oil inside the motor. Quite simple.
See to it the old gasket is scraped off so the motor side surface it flat. A single edged razor works well. Avoid the old gasket debris falling into the opening.
PM me your E mail and I will send you the full shop manual which you will find useful for this and everything else you will encounter. The fuel supply pump discusion is at page 3-30
Charles
51
Thanks, Charles. Good tips. I have the service manual already but appreciate the offer. Dan
Ted
Jan 26, 2005
1,280
It's a pretty simple project if you have decent access to the fuel pump bolts. You can do it!
May 27, 2004
2,059
Charles, I could use the manual if you have the time.
ggrizzard@cfldotrrdotcom
Thanks,
G.
MitchM
Jan 20, 2005
1,031
it's a kind offer from Charles to send off the service manuals for this yan mar engine. one can also join boat diesel.com and get access to the install service and parts manuals for just about any diesel or gas engine. once you are a member you can scan their archives and post questions for answers to a very wide audience. boat diesel has helped me with a number of boat technical issues over the years. it's a good bargain.
