My 1986 C-25 has hatch boards that seem to have been systematically worn or machined down along the edges. The boards are the usual 3/4" thick, but the ends of the boards are thinned down to about 1/2" or a bit less. This doesn't seem to be the result of wear, as it is very uniform, but seems to be something the previous owner did. At any rate, because the boards are thin on the ends, they flop around in the channel and when they are in place, the top ones tend to slip down over the ones below, leaving a gap above the top board. Each board consists of a long piece of teak with the grain running horizontally, and a shorter piece on each end with the grain running parallel to the edge. They are assembled with tongue and groove and some sort of adhesive.Has anyone ever replaced the teak ends of the hatch boards? Buying new boards is quite expensive, making new ones will still run about $100 for the teak, but if I can simply replace the end pieces, it will be far cheaper. Does anyone know what the adhesive is that holds the pieces together?
