Repairing a wooden mast
wetass
Mar 9, 2011
190
CS 36T Seattle
I have come into possession of a 50' wood mast that came off a boat that sunk in our local marina after a propane explosion. Now I don't want to use the mast for my boat, but rather mount it in our yard for a flag pole (its a beach house). The problem is that it has some rot at one of the spreaders - Its a box section and the rot is pretty much confined to one corner of the mast. Having never owned, or repaired for that matter, a wooden mast, I am looking for some guidance.
Do you simply scarf in a new section, or are there better ways? I'm leaning toward just scarfing in a new section at the corner with a good amount of bevel (12:1 or more) and use epoxy and wood-flour as the glue. It doesn't have to be offshore capable since it will never see a sail, but I also dont want it falling on the house.
Thoughts?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Thoughts?
it can be done and i like your idea of the flag pole...would you post the damaged area for us ....i would like to see how it is constructed be fore i suggest anything in the order of repair....
regards
woody
wetass
Mar 9, 2011
190
CS 36T Seattle
Will do, but will have to wait until this weekend before I can get pictures. Thanks for the reply!
zeehag
Mar 26, 2009
3,198
there should be a reinforcing box inside that mast at the spreaders. you may be able to get away with git rot, as it isnt going offshore too far.
wetass
Mar 9, 2011
190
CS 36T Seattle
Git rot or Rotfix may have been an option BEFORE I dug into the rot with a screwdriver and tore out a good portion of the rotted wood - Ooops. Now I think Im stuck replacing the wood. Thanks for the suggestions though Zeehag and Justsomeguy. You are right though that there does appear to be a reinforcing box, or at least some additional wood underneath that rotted section that appears unaffected.
zeehag
Mar 26, 2009
3,198
ok since is a box under, as is spozed to have, add filler to the git rot/epoxy repair stuff and is good to go. fair it nice--like repairing yer old vw bug/bus --isnt gonna go too far offshore......
