Repairing a power winch
Dan
Jul 26, 2006
190
Hunter 420 Stamford
My power winch trips the breaker when the sail is about halfway up the mast. It also draws more amps than it should. I contacted Lewmar and they said they no longer support the product. Grrr! Any suggestions on what I might do to fix it?
Ross
Jun 15, 2004
14,693
Have you attempted to raise the main by hand?
The load may be too high for the winch. Check the no load current draw. There can be several reasons for the problem and they might not be in the winch.
Dan
Jul 26, 2006
190
Hunter 420 Stamford
It shouldn't be too high a load
well, the winch was installed just for this purpose -- it's the winch Hunter included for raising the mast.
Dec 2, 2003
4,245
- - Seabeck WA
Hmmm, DC motor,,,,
Never been into one of these units,,,but, it's a DC motor. Can you pop the end cap off of the housing? You know, the part that keeps things from being seen. Sounds like the brushes have worn and the resultant dust is letting current go to ground. When that lost current and the load increase from a nearly raised sail combine to reach the trip-point of the breaker, well, it trips. First thing to check. Usually the only expense is a new set of brushes, if that. Good luck. And what's with Lewmar not supporting a product that's only 7 years old. Who the hell is in the White Ho,,, oops, sorry Phil.
Dan
Jul 26, 2006
190
Hunter 420 Stamford
Thanks
Thanks, all. Not being much of a DC motor maven, I'm hopeful after reading the advice. I'll pull 'er apart. Shouldn't be too hard. After all, if we can put a man on the moon . . . Just one question....where would I find the right brushes?
Dec 2, 2003
4,245
- - Seabeck WA
For brushes I would look in the phone book for
a DC electrical repair shop. We have one. If your old ones are worn out (and it doesn't sound like it or the breaker wouldn't be tripping) take them to the shop and they can match-up something. Or google. I can't believe Lewmar is backing out of supporting your winch! That borders on CROOKED!
Feb 10, 2004
4,248
Hunter 40.5 Warwick, RI
Dan, which model electric winch do you have?
I'm wondering if it is the OP2 or one of the right-angle drive models.
Dan
Jul 26, 2006
190
Hunter 420 Stamford
Hmmm....not sure, BUT
I will be visiting the boat this Saturday with renewed interest. I'll try to pull the winch. Stay tuned!
Dan
Jul 26, 2006
190
Hunter 420 Stamford
I was on the boat, and . . .
The winch is a Lewmar OP2, not a right angle drive. Any insights, Rich?
Dan
Thanks!
That's helpful. Thanks. The breaker trips when the main is about two thirds of the way up. So there's still a ways for the sail yet to go. The mast is down, now, so I'll be sure to lubricate it before it goes up in the spring. I'm still thinking that it's drawing too much amperage. I still intend to do some maintenance on the winch innards and do some investigating regarding the motor. Perhaps it's corroded, or something, which would increase the resistance and hence, generate heat and strain the system. I got a lead on a guy at yachtmd.com who works on windlasses. I'll let you know.
Feb 10, 2004
4,248
Dan- OK, thanks
If you get any info on the tripping, please let me know. I am under the belief that it is normal for this model winch. Watch what you use to lube the mast track. Lots of lubes can attract dirt and make the problem worse. I think I would simply clean the track with soap and water and rinse it completely. I have used a product like Sailcote and that seems to help without leaving a dirt-attracting residue. I think the best solution is to have a friction-reducing track system. In addition to making the sail go up a lot easier, it also comes down nicely too. The full-batten mains tend to bind at the battens and fight you all the way. A track system eliminates that problem.
