Marina
Hello,I have a Hunter 27. There is a small crack in a section of the hull. A year ago, the marina put the boat on the cradle backwards. I want to repair it soon. I have a lot of experience in fiberglass/resin repair. However, I was hoping I could get input from you fine sailors here. Here is what I have planned. Since the repair needed will be under the water line, I figure that details will not be too important. I will sand off the antifouling paint. Then I will rough up the gel coat with 60 grit paper with my random orbit sander. I will purchase my glass cloth and use laminating resin (Pre gelled since I will be working on the under side. After I have placed about 7 or 8 layers of cloth, I will sand a bit just to blend it all together. Then, I will put antifouling paint down over my work. That is my general plan. I am not going to have this job done by a company. I know that some may suggest that a "pro" is the only way to go. But assuming that I am going to do this thing my self, I would appreciate any input you may have. Thank you in advance,Marina
