Bill Wilkes
I am looking at several Catalina 25s which are for sale. One which is otherwise apparently a good buy has numerous (lets say 40-50) small (1/2" dia or less) blisters on the hull which appear to have been "repaired." The owner says he drilled each blister and filled it and has had no problems with them. Each "repair" looks about as one might expect - an area with some discoloration and a hole or crack in the middle which has been filled and is flush with the rest of the surface. If I buy this boat, I would expect to do an overall sanding on the hull and then put a coat of VCTar or other epoxy to cover the entire thing so as to prevent future blistering. I would appreciate comments on the degree to which I should be concerned about these blisters and my proposed solution.
