Repair / replace bulkhead liner fabric for 1983 Oday 25
May 6, 2014
11
Oday 25 Herrington Harbour North, Tracey's Landing, MD
Not sure if this posted yesterday. I am replacing the cabinet shelf, sink, and upper shelf on the starboard side of the cabin across from the porta-head. There was a leak from stay plate that has been remdied.
The bulkhead fabric liner is fairly beat up. Would like to replace it, but don't know if it can be purchased anywhere. Any suggestions where I can find some, or alternatives, are welcome.
Thanks.
Dan
Sep 25, 2008
992
Oday 25 Gibraltar
I replaced mine when I rebuilt mine.
I bought this- http://www.yourautotrim.com/huhfa.html
http://www.yourautotrim.com/perhittrimad.html
When you remove the old liner, save it for use as a pattern, if you can. Mine was separating from the hull so it came off fairly easy.
Installing the new stuff goes pretty easy, easier than you would think.
Check the archives from around 2009 or so, there was a bit of discussion on this topic.
If you want more info you can message me
Erieau
Apr 3, 2009
209
Oday 25 Erieau
Can't really help you with a "liner" replacement, as my original was teak-laminate plywood.
However, I gutted that area during a refit a couple years ago, and replaced the bulkheads entirely. Now they're white-painted plywood. The vanity is replaced with some wire shelves (picture shows my first try at it, now the shelves to all the way across), and the sink is on a shelf behind the head.
Maybe it'll give you some inspiration?
Erieau
Apr 3, 2009
209
Oday 25 Erieau
Ah, RBone's reply shows you may have meant the hull liner.
I replaced mine with brown in/outdoor carpet. Wire-brushing off the old adhesive was an awful job. The new stuff is glued on with carpet glue, which took a good week to dry. If you go this way, don't trowel it on too thick, as it tends to squeeze through the carpet.
Sep 14, 2012
29
Oday 27
Here's how that opposite-head area looks now. Indispensable for bed-clothes storage. The canvas keeps everything in place while underway.
Also, the new sink behind the head. I made it from an SS mixing bowl from Target.
Looks great. The mixing bowl from Target is genius.
May 21, 2013
23
Oday 25 Fern Ridge
Replaced our entire hull liner with an outdoor carpet from Home depot. Glued it in place with carpet glue. Still in great condition a year later and
less than $100 in material.:dance:
