I have a 1984 Universal 18. It appears that the exhaust pipe is broken [pipe is wrapped in asbestos(?), between the exhaust hose and the engine]. Where can I get a replacement? What are my other options?
The part that you are refering to is your mixing elbo. Your best option is to take it out and have a yard make up a new one. Its quite easy. It just takes some time to remove it. You have to remove the teak panel to access the part. I had Catalina make up my replacement part, however I was not happy at the amount of time it took for them to make it up...The cost was around $125...good luck
