If it was my boat.........
My Gulf 32 is getting a bit old around the non-skid. It is of the "stippled" gelcoat sort.Except for the cockpit (see below) I have a few superficial cracks but the deck is generally in great condition and would have been even better if I had a boat cover. crack (on the coach roof) has rust stains from a bolt. What I am going to do (when I get time!) is to throroughly clean the deck(IG clear , then pink), repair the worst of the cracks (color-marched gelcoat) seal ithe whole deck with a couple of coats of our new sealant. If should protect against further weathering. The way I am going to make the repairs "invisible" is to color match and blend the color, using a latex mold or dremel to make the suface texture match.The cockpit is another thing. I think that painted non-skid often looks amateurish, especially if not done really carefully, but there are so many cracks! Also when ocean sailing, slop from waves evaporates into a salty slurry that is VERY slippery. I used to stand on a towel!For this reason I think I will sand down into the deck and use painted non-skid (two part- like Awlgrip, with the grit that they sell). ALternatively a nice teak grid would be nice!.Enough about me- Now how about YOUR boat?If the moulded non-skid deck is not cracked is in good shape, I would remove that paint (if a singlel part- otherwise you cannot without damage to the gelcoat. and then restore and protect with our system. If it's all the same material its easier to take care of and re-gelcoating is easy if you need to do repairs.If you do pain the non-skid try to use a really good quality (I prefer two part) PU or epoxy and if you use fine grit it won't alter the appearance of the mooulded in pattern.Now these are only personal opintions - La Donaa of Catalinaowners.com has done painted non-skid and can help you . Also I have a customer (a Mr WIlcox) who had a two-part awlgrip deck done professionally. I can get his e-mail address for you if you contact me offline (via IG site).I am still preparing a sort of essay on non-skid but thought that I should actually finish the job on my boat before posting it on this site.If anyone wants to completely redo "stippled" non-skid with gelcoat, Dave Collignon of Fiberglass Hawaii (Santa Cruz CA, ) has done this many times as part of his boat-building and surf-board backbround.ThanksALW except for the cockpit where there are more cracks and I am not satisfied with the grip anyway for ocean sailing
